SignalExpress
Does Signal Express support ActiveX?
I would like to write LabVIEW code that can launch Signal Express in the background, run a project and return result remotely.  Can this be done with ActiveX?
Roger
(6,588 Views)
Hi Roger,
I am not sure if you can use ActiveX to lauch Signal Express, but there are Signal Express VIs that are found in LabVIEW that allow you to do the same thing as in Signal Express. There is a whole palette of VIs designated for Signal Express. If you go to the functions palette, you will see a category called Signal Express and then you can find several different VIs. You can also generate LabVIEW code from Signal Express. If you have a program setup in Signal Express, you can go to Tools>>Generate Code>> LabVIEW diagram. This will create LabVIEW code from the setup that you have made in Signal Express. I hope this helps!
Carla
(6,579 Views)
