SignalExpress
Vista compatibility chart
I have searched the NI site for a general NI software Vista compatibility chart and only found a general Vista video and a Signal express bug for not displaying the licence number.
It may be a sensetive topic showing in full where NI is with Vista compatibility (inc 64 bit) but us customers need to know?
There may be a chart and I just can't find it? Appologies if there is.
Regards
Andy
(6,807 Views)
Hi Andy,
Here is the link you require to see hardware/software support for Vista: http://zone.ni.com/devzone/cda/tut/p/id/6893
All the best,
(6,803 Views)
Hi Rob,
Thanks for the chart - many apologies!
The trouble now is I still don't know if Signal Express 2.5 is Vista 32bit compatible as it's not mentioned in either the XP or Vista coulomb's?
I received the SE 2.5 with my developer suite.
Regards
Andy
(6,799 Views)
Hi Andy,
I'm not sure why that isn't listed in the table, Signal Express in all of its versions is fully supported by Windows Vista and you can check for updates at http://www.ni.com/vista
Hope this helps,
All the best,
(6,796 Views)
