SignalExpress
Error 200279 in SignalExpress
I'm using a full-Version of SignalExpress 2.0 with a cDAQ-9172 with NI9205-Module and NI-DAQmx 8.5. SE is configured for continous sampling two voltages with 1k-Samples per read and 10kHz Sample rate. In the recording options, I defined a leaving-window-Trigger to start logging with a 5s pretrigger and an entering window to stop it again (5s posttrigger).
 The problem is, that the logging crashes with error 200279 shortly after trigger-event. I've searched the web, but only found solutions for Labview. Turning off "Prepare log data for viewing" did not help. There is nothing but SignalExpress running on the computer.
Has anybody a tip?
Thanks in Advance.
(6,076 Views)
please read this KB in order to track down why your DAQ is overflowing.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KTeSAM&l=en-US
M. Brauner NIG
(6,054 Views)
