SignalExpress
Triggering on frequency entering and leaving window SignalExpress Bug
In the recording options of SignalExpress,  when one sets up a trigger to trigger entering or leaving a window of frequencies, This does not work properly.
I was using a Signal Acquire Voltage step, then doing Tone extraction on the Voltage channel.  I hooked up a frequency generator to the voltage in.  As I ramped the frequency of the generator up and down expecting the trigger to start logging to disk, I was sadly dissapointed to not see this work properly.
As a side note, I also had a voltage threshold trigger set also, now that I think about it and the Trigger Logic was set to OR, but this shouldn't have anything to do with the problem
Can anyone Confirm?
Ben Yeske
(6,243 Views)
Please post your project and and as many details of your hardware setup as you can so we can reproduce this.  Thanks!
(6,228 Views)
This Problem has been confirmed and had been issued a CAR(Corrective Action Request) # 180783.
Ben Yeske
(6,219 Views)
The hardware involved was a USB-Compact Daq Chassis.  I was using the NI-9233.  The Recording log was set to trigger on leaving a window of frequencies.  The frequency parameter was acquired from the tone extraction step on an analog voltage channel.
Seems pretty straightforward to me, and one should be able to reproduce the inconsistent entering window/leaving window triggering behavior with a wide variety of hardware.
Ben Yeske
(6,217 Views)
