SignalExpress
Evaluation - Importing a Signal from a File
I am trying out SignalExpress 2011 in Evaluation mode.  The only steps I see in Project Vew and "Add Steps" are to "Aquire Signals" and "Generate Signals".
Did I miss something in the installation?
thanks,
bk
(5,636 Views)
Click on Tools>Options...>General. Be sure that "Show unlicensed steps" is enabled.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,633 Views)
"Show Unlicensed step" = Yes.
I actually downloaded the NI Drivers pack for 2011, went through the install (and installed Signal Express 2010) and everything seemed to work.  I messed around with it for a  bit last week, but then when I went to open it today, only "Aquire Signals" and "Generate Signals" are available again.
Can you think of something else to try?  Thanks for your help.
(5,611 Views)
Hi bk,
I think maybe your version is not licensed properly and the evaluation mode has expired. If you open the NI License Manager (Start >> Programs >> National Instruments >> NI License Manager) you can check the status of your SignalExpress license. Expand the listing for SignalExpress and check to see if there is a dark green square next to either Full Version or Limited Edition, and also see if there is a serial number listed for whichever one has the dark green square.
If it is not activated (no dark-green square), you can right-click the version and select "Activate" then try to use your serial number from your LabVIEW installation to activate SignalExpress.
Daniel H.
Daniel Hays | Test Software Business Manager
(5,600 Views)
