SignalExpress
signal express thermocouple display
In the step setup tab, the display of my thermocouple readings are displayed in amplitude instead of actual temperature.  This has not happened before.  How do I change the amplitude back to temperature display?
(6,018 Views)
Hi jjfang,
The preview section of the Step Setup tab is purely for a quick monitor of the signal, so the scale will only show amplitude rather than changing to the actual signal type and units.  In order to see that information, you will have to use the data view tab.
(6,010 Views)
Alternately, you could switch the Display Type from Graph to Table in the Setup Tab and it will display the numerical value in whatever units you've selected.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(6,001 Views)
