SignalExpress
LabVIEW SignalExpress -- Keystroke Event
I'm trying to record keystroke events while recording analog voltage signals with SignalExpress.  The first time that I set this up in the project and record a signal, the keystroke events are recorded.  However, when I try to record a second signal, the keystroke events do not record.  Can anyone help explain why this is  / how I can change it so that the keystroke events continue to record?
Thanks!
(5,759 Views)
Hi lhs,
I see you're having a problem with logging keystroke events while recording two signals. Are you trying to record these signals at the same time. Also, are you running this continuously? If not, I would suggest trying this so that the program is continuously monitoring for this keystroke event. Can you give some more information about your application? What kind of analog signals are you trying to record? Did you add anything else between the recording one signal and when you tell it to record another signal?
If you could either attach your code or some screenshots of it, it would be a great help in debugging.
Lea D.
Applications Engineering
(5,743 Views)
