SignalExpress
Signal Express code generation
I am using 2011 vewrsions of SE and LV full development system and trying to generator VI's from SE.  The projects run, but when I go to tools and attempt to use code generation,  Labview Diagram in never hi lighted.  Have re installed Se sveral times.  Please advise,means to link SE and LV if necessary. All run on PC under Vista.
CEK
(5,888 Views)
There are a couple of immediate possibilities:
  1. You are using a 64-bit version of LabVIEW.  SignalExpress does not currently generate code to 64-bit versions of LabVIEW, although this should result in a warning of some sort.
  2. You have changed the VI server settings in the LabVIEW version you are using.  Under Tools»Options»VI Server, the ActiveX protocol should be checked/enabled.
Let us know if neither of these work for you.
(5,884 Views)
Yes, I finally found a reference to the 32 vs 64 bit issue and have downloaded a 32 bit version.  Will know today if that works.  Will look at recommendation #2 also.  No, I received no error messages.
Thanks for the advise,
Chuck
(5,882 Views)
