SignalExpress
Exporting part of signal to ASCII or excel
Is it possible to select a part of the logged data and export it and not the whole recorded data?
Munir
(6,669 Views)
Hi Munir,
Add the following two steps to your project:
1) Processing >> Analog Signals >> Subset and Resample
2) Load/Save Signals >> Analog Signals >> Save to ASCII/LVM
Are this the functions you are searching?
Maria
NIG
(6,625 Views)
Accepted by topic author mbhatti2000
Hi Munir,
In addition to Maria's suggestions, you can also do the following:
1. In the Log window (which is by default in the bottom left of the main application window), expand the "+" symbol next to the log you want to export.
2. Right-click on the top level group of data, and select "Create Log Subset" (as shown below). This will open a dialog which will allow you to create time subset of your selected data. Either use the Start Time/Stop Time indicators to make your subset selection or use the red cursors on the preview graph. Then click on Create.
3. Once the dialog disappears, you'll have a new log entry with the same name and the word "subset". Expand that new log subset, and right-click on the top level group. You'll have 3 export options: a) convert to text, b) Export to Microsoft Excel, and c) Open in DIAdem. Select the option you want.
20367iFF8381797C3ED859
Hope this helps too.
Phil
(6,589 Views)
Thanks a lot Maria and Phil..........Phils answer was exactly the one I was looking for. But thanks Maria for the your answer, it might come in handy in the future  Smiley Happy
(6,585 Views)
