SignalExpress
FFT result for a sine wave
I am computing the FFT of a complex sine wave using the FFT vi. I am able to see a peak at the frequency but I am a little confused since the FFT of a sine wave is a delta function. Does this vi use any window function and so it has a lobe instead of a peak?
Can anyone please help me?
Thanks!
(5,694 Views)
Hi Bsharmi,
Seeing as how this is a LabVIEW issue, I would post this on the LabVIEW section instead of the SignalExpress one.
That being said, there is noise in your sine wave function so it will not be a perfect delta function. The noise introduces other frequencies into your analysis. This can be seen in your sine wave, as it is not a perfect sine wave but one with noise.
Paolo F.
(5,657 Views)
