SignalExpress
How do I compare results in multiple logs?
I have a SignalExpress project with many logs.  I would like to compare results that are spread across multiple logs (their power spectra, in particular).  How can I do this in SignalExpress without needing to export each individual log and using other software to do the comparison?  I feel like I must be missing something, as this should be easy.
Josh
(5,799 Views)
Hi Josh,
Do you have Signal Express Full Edition or Lite? If you have Signal Express LE, there are limitations to data analysis and exporting to spreadsheet files is the only way to log data unless you upgrade your version.
Please let me know if you would like to upgrade and we can get this process started.
Jackie
DAQ Product Marketing Engineer
(5,692 Views)
For now I'm using a trial version of the Sound and Vibration Assistant (will actually be sending over the PO to purchase it later today).  So, for the purposes of this, it's the Full Edition.
(5,688 Views)
