SignalExpress
How do I display the real-time data in the Chart legend of SignalExpress?
I am currently using SignalExpress 3.0 to plot 6 signals from pressure transducers. Right now, when I go to the Data View of the chart and display the legend, I just get colors. Is there a way I can get an actual real-time readout of the signals in the legend in addition to the colors? I am pretty sure that I have seen this before. Any help would be greatly appreciated.
(6,148 Views)
Hello rpowell,
What Acquisition Mode does your application require? If you set it to 1 Sample (On Demand), this displays the value in the legend. However, a continuous acquisition will not enable you to do this. You can set up a table to view the most recent data points.
Glenn
(6,136 Views)
I found the answer. I just need to get the DC and RMS of the signal and plot the DC value. This allows me to see the actual values in the legend for continuous sampling. Works great!
(6,133 Views)
