SignalExpress
How to create and send AC signal out in signal express?
I'm using signal express 2010 to create an AC signal. The AC signal is created initially. Now I want to send it via NI PCI 6010 to control pulse width modulation, for example. The problem is: i cannot get the connection diagram. I don't know how to use the help. Everytime I tried to open the example files, the signal express off itself automatically. Its a licensed version.
I need examples to know how to create a signal, then send it via Analog Output. I don't get the CB-37F-LP Quick Reference Label in internet. So I don't know which pin is given for AO1 and AO2.
I'm also using another computer with signal express 2009, PCI 6221 with SCB -68 connector. The connector has legend to tell which pin is given for analog output. Whereas the  CB-37F-LP has nothing to indicate the connections. However the NI PCI 6010 can acquire signal as I have tried in few cases.
Now I need an example to know : HOW TO CREATE A SIGNAL AND SEND IT VIA ANALOG OUTPUT.
Pls help me.
Message 1 of 1
(5,685 Views)
