SignalExpress
How to perform frequency response on data subsets
I have limited experience with SignalExpress.  I have created some large data logs (around 10 GB) over an hour of recording.  I have figured out how to do a power spectrum over the whole log, but what I really need is to do are power spectrums at some interval.  So after some period of time I don't care about, I want to analyze a second or two of data (or some x samples would be good as well).  If SignalExpress can spit graphs out as images or something else I can use, that would be great.
To take this a step further, the logs have multiple elements in them.  If I can automate the analysis so each element is done seperately, that would be great.  But doing what I asked about above where I have to manually select the element would still be sufficient for my needs.
I am sure someone has asked about these things before, but after days of searching I have come up empty handed.   Thanks for looking and any direction you can provide.
(3,670 Views)
Do you have an option to use LabVIEW over SignalExpress or are you limited by SW?
(3,660 Views)
