SignalExpress
Subtract one signal from another
Hello NI SignalExpress community,
I am new to Signal Express. I would like to measure the coolant temperature of one machine sub-system. The difference of temperature and the coolant flow rate would enable me to measure the power dissipated. Could someone tells me how to substracte two signals? I would like to see in real time the temperature difference. Thank you for your time.
Best,
Renaud
(3,831 Views)
Create a Statistics step (under Analysis> Time Domain)
Check the box next to mean (uncheck min/max if you want)
Create a Formula step (Processing> Analog Signals)
In the Formula step Input variable 0 should be signal 1 (x0)
Check the Enable 1 box to add a second variable (x1)
In the formula Y=x0-x1
This will be your Processed Data which can be drag and dropped into a graph and viewed however you want; ie, graph, numerical, temp gage, etc.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(3,818 Views)
