SignalExpress
I am collecting data at high frequency and controlling a rig at the same time. I want to trigger Signal Express to start and stop from inside my LAbView program. How do I do it?
Have you considered generating LabVIEW code from your SignalExpress project and integrating that into your LabVIEW program?
(6,093 Views)
This knowledgebase and this knowledgebase should enable you to generate your code in signal express and import it into LABview.
Best Regards,
Mike W
National Instruments UK&Ireland
(6,087 Views)
