SignalExpress
Is TEDs transducer informatio​n saved in the .tdms file?
I have a TEDs-capable Pressure Transducer connected to a NI-9237 module in a cDAQ-9174. In this application, I am collecting data using SignalExpress 2014. The attached file shows the information displayed in MAX, for the TEDs-capable transducer. When I collect the data, is the TEDs information saved as metadata into the .tdms file? I do not see it in the channel properties within DIAdem. Thank you.
Message 1 of 1
(5,237 Views)
