SignalExpress
"Data could not be exported. This feature is only supported for time continuous logs. lease use the Convert to ASCII feature instead."
I am having the problem when trying to export data to text.
SignalExpress used to export the data but now doesn't. Not sure what changed but reset all the setting back to default but still get the error. The date I am recording is continuous so, how do I set SignalExpress to relaise that?Thanks.I'm using version 3.5.0.
(5,420 Views)
Hi isenhand,
My name is Marius from the National Instruments AE team. Could you possibly post a screenshot of the error message? Also could you post a sample of the data you are trying to export to text?
Kind Regards,
National Instruments UK & Ireland
(5,404 Views)
