SignalExpress
LabVIEW Compatibility with SignalExpress 2015
We use SignalExpress 2015 a lot in our course of work.  The problem we are having is we don't know what versions of LabVIEW SignalExpress 2015 will read.  I know it will read for sure LabVIEW 2015, but what about more recent versions of LabVIEW like 2016 and 2017?  We have upgraded a few systems to LabVIEW 2017, but just can't seem to get the SignalExpress 2015 to be able to read the VIs from LabVIEW 2017.  Is there something special I need to do, or is this just something that I need to go back with LabVIEW 2015 to be able to make it work?
(4,762 Views)
Hi daniel.e.roberts1!
Thanks for the question. It looks like Signal Express 2015 is compatible up to LabVIEW 2015. See under Application Software in file below:
SignalExpress 2015 Readme: https://www.ni.com/pdf/manuals/374767b.html
Is it possible to use task in NI MAX instead of using Signal Express?
Thanks!
(4,709 Views)
