SignalExpress
Limit Step - Timestamp off limits
I've acquired some data from a Tektronix DPO3034 scope using labview SignalExpress 2011 5.0.0.
The data is a set of 4 waverforms each 100seconds long captured each time the scope triggered.  It was running overnight so I will have somewhere in the region of 500 captures.
What I am trying to do is analyse one of the channels using a limit test to see if any of the waveforms fall outisde expected limits.
The attached image shows the waveform and error I am getting
The details are
"Error occurred in Limit Test step.
The specified time stamp is after the end of the limit."
If I try a user defined constant as the limit then it seems happier but what I want to do is put a tolerance on the waveform that is shown in the image.
Any suggestions?
Stephen
(6,043 Views)
Hey Stephen,
Do you want the good new or the bad news first? Bad news, right? Always start with the bad news!
Bad News...
Although I had never used the "Limit Test" step before, I have just been played around with Signal Express and managed to replicate the issue you saw (The specified time stamp is after the end of the limit).
Good News...
I have worked out how to resolve the issue. When the Limit Test Step is configured to work with "User Defined Signals" is requires the data to be forematted in a particular way. Specifically, it seems to require the default header that is applied when saving an LVM file.
For my test application, I dropped down a "Load from ASCII" step, which read some noisey sinusoidal data from disk.
I then place down a "Limit Test" Step, configured to work with User Defined Signals, Between Limits and Signal Limit and Range. I point this step at a limit file that contains a clean sine wave. This file also includes the default LVM header information. This allowed the limits to be loaded correctly, as you can see in the following screen capture.
I have attached zip file, which contains 2 .lvm files I used here; one contains the data (noisey sine wave, with a time column) the other conatins the limit information (header, plus clean sine wave).
I hope this has been useful Stephen.
Best wishes with the rest of your application developement.
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(5,986 Views)
