SignalExpress
Playback data faster than it was logged?
I have a large amount of data to process post acquistion using the playback function.  Is it possible to speed this up rather than watching it at the logged speed?
(6,561 Views)
There is a new menu entry in SignalExpress 3.0 (which recently released), called "Operate". In the Operate menu there is a submenu called "Set Playback Rate" which allows you to select a playback speed; both faster and slower than the actual acquisition speed.
Note that in certain cases, I have found that selecting a playback speed of "1000x" instead of "As fast as possible" gives me faster playback.
I hope this helps.
Phil
(6,544 Views)
