SignalExpress
Please help me in interfacing Lecroy oscilloscope with labview signal express ???????
Please help me in interfacing Lecroy oscilloscope with labview signal express ???????      I am using USB cable to communicate with lecroy waverunner 610zi scope using signal express.... now the problem is in configuration... I have installed the particular drivers to communicate .... after opening signal express - acquire signal to ivi scope acquire then session name is myiviscope , resource descriptor is USB and driver is lescope(leccroy scope) but after after clicking the run it shows error as
ivi_IviScope Initialize With Options.vi<ERR> Primary Error: (Hex 0xBFFA004C) The option string parameter contains an entry with an unknown option value. Elaboration: LeCroyScope: The True value in the option string is unknown.  Interchange checking is not supported by the driver.
  <b>Complete call chain:</b>       ivi_IviScope Initialize With Options.vi       ivi_subScopeGetReleaseSession.vi       ivi_subScopePreExecute.vi       ivi_InstrSCOPEBlockState.vi:2 ....
. please help me out in this and if i installed the drivers wrongly please suggest the specific IVI drivers to communicate with lecroy oscilloscope waverunner 610zi.........
Thanks , karthik
Message 1 of 11
(9,469 Views)
Hi karthik,
Which driver have you been installed exactly?
And which interfaces are you using exactly to communicate with your lecroy waverunner 610zi scope:
USB, IEEE 488.2 (GPIB) or Ethernet
Regards
Carina
Message 2 of 11
(9,445 Views)
Hi carina,
        Thanks for your reply.... I am using  USB cable to communicate with the lecroy waverunner 610zi, I have  installed IVI driver i.e plug and play driver type..... I don't know which driver is to be installed for this specifications.... could you please suggest me the exact driver for this......
Thanks.
Message 3 of 11
(9,442 Views)
Hi carina,
    I am sorry for drivers i have installed only IVI drivers not plug and play....... thanks
Message 4 of 11
(9,440 Views)
Hi karthik,
could you please send me a link to the driver you are using?
I´m sending you a few links with the NI driver for IVI and an instruction for using it with signal express.
LeCroy WaveRunner 610Zi Driver:
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=19159
IVI Instrument Steps in LabVIEW SignalExpress:
http://digital.ni.com/public.nsf/allkb/589469164F1FCC0F86256FFF007368AD
Example: Using IVI Scope Acquire
http://zone.ni.com/reference/en-XX/help/371268M-01/expresswb/ivi_example/
I hope these links would help you.
Regards
Carina
Message 5 of 11
(9,432 Views)
Hi carina,
                   Thank you for your reply... The links which have you sent I downloaded the drivers from the same link before..... But still the configuration errors occured.. Can you suggest me how to change the configuring settings in the Measurement & Automation to acquire the siganl and to make configuration error free....
Karthik.
Message 6 of 11
(9,427 Views)
Hi karthik,
Have you already tried to change the interface, either Ethernet or GPIB?
Please also have a look at point 2: Required Software at the Readme file and check if you have installed the VISA driver.
LeCroy Wave Series Instrument Driver Readme:
file:///C:/Users/grrothc/AppData/Local/Temp/Temp1_lecroy_wave_series.zip/LeCroy%20Wave%20Series/LeCroy%20Wave%20Series%20Readme.html
Regards
Carina
Message 7 of 11
(9,413 Views)
Hi carina,
            Thank you for your suggestion let me try to interface through ethernet and also I need to install VISA driver... I have another doubt are you sure the link that you sent for the drivers is applicable for Labviewsignal express or only labview2010(32-bit)
Karthik
Message 8 of 11
(9,410 Views)
Hi karthik,
I´ve tested this driver and it seems that it works only in LabVIEW but not in Signal Express, sorry.
Regards
Carina
Message 9 of 11
(9,408 Views)
Hi Carina,
 Thanks for your reply.... Do you have any idea which drivers will work in Labviewsignal express.
karthik
Message 10 of 11
(9,405 Views)
