SignalExpress
Display Temperature and Current in one chart
Hallo,
I am using two cDaq devices, NI9227 (Temperature) and NI9214 (current) with Signal Express 2012. I have tried to displayed both Data in on Chart, but without success. When I drag a current channel to the Temperature Chart a new Waveform Chart will be created. Is it possible to display both data in one chart?
Lars
(6,107 Views)
It is possible to display them both on the same chart, but only if they are the same data type.  For example, if the temperature is output as a scalar and the current as a waveform, they will go on different charts.  If the are both scalars, they should both go on the same chart.
(6,101 Views)
Thanks for the hint. Now I used the Statistics Function to calculate the mean value from the waveform signal. But when I display this to a chart the timestamp is missing. How do I add a correct timestamp to this signal.
(6,097 Views)
As SignalExpress currently stands, scalars do not have timestamps, only waveforms.  Please add your voice to support of this feature on this page.  Thanks!
(6,082 Views)
As you see in the picture below, the "Current" X-Scale is formated as Iteration.
When I change the properties to "Absolute time" these settings are not saved. Is this a bug?
(6,079 Views)
