SignalExpress
Problems after calibration with Signal Express
My system is scxi-1000, scxi-1600, scxi 1100 and scxi 1303.  I had instaled 10 thermocouples type K, the problem occur after the calibration process in SignalExpres, the measurement has difference of +/- C deg with the reference equipment.  The interval for calibration is 2 to 40 deg C with a step of 1.
Please help me, what I can do?
(6,353 Views)
So what you mean is that after the calibration the equipment stoped to work well?
Could you please explain a little better?
Thanks a lot.
Best Regards
Luciano Borges
Test Development Engineer
(6,309 Views)
Yes, after calibration the sistem does not work well, it show a wrong temperature reading. What information I have to show for resolving my problem? Thank you for helping
(6,300 Views)
Si haces la calibración otra vez, que ocurre con las mediciones?
Gracias.
Cordiales Saludos
Luciano Borges
(6,283 Views)
