SignalExpress
Recording options; 6 sec every 15 min. But need to start immediately not 15 min from now
This is the first time I've had a chance to use the Recording Options.
I'm trying to acquire 6 seconds of data every 15 minutes unattended. I've set my Start Condition to "Date/Time" and Schedule Start Time to "Hourly" with the interval being 0:15:00. Start Logging is set to "Immediately"
Stop Conditions is set to "Duration" with duration= 6sec.
However when I start logging it waits the 15 min before it takes the 6 seconds of data.
Is there a way to log the 6 seconds of data immediately after hitting RUN (as the Start Logging condition implies) THEN log every 15 min after that?
Message Edited by OKors on 04-21-2010 11:17 AM
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,716 Views)
Hello OKors,
Rather than setting the start condition to 15 minutes, I would recommend setting it to 0 minutes (start immediately), and then set a Stop Holdoff of 15 minutes, so that it waits 15 after the recording stops before checking for the start condition.  I think that will accomplish your goal.
-Christina
(5,689 Views)
