SignalExpress
Saving chart output into a text file
I have a question concerning the delelopment of software in Labview Professional.
I am developing a program which monitors the output of pressure sensors. It simply shows the result on the chart constantly, and should save it in a text file. However, I have a problem of saving it properly. I tried different ways but it saves only the last result (replaces the results one by one), or saves 100 results for 1-2 seconds.
Could you please advice the best way of implementation in that case?
(4,468 Views)
Again, you have posted to the wrong board. SignalExpress is an application written in LabVIEW.
(4,461 Views)
