SignalExpress
Scaling and Conversion
when I use the scaling and conversion step, the output unit is expressed as the input unit;
given the fact that I am converting, it would be useful to be able to change the unit; I probably missed the option.
How should I do ?
Thanks.
(5,662 Views)
Hi.
the espress VI "Scaling and Conversion" is used to oerforms gain and offset scaling on a time signal, gain scaling on a frequency-domain magnitude signal, or time-delay correction on a frequency-domain phase signal. The configuration options you can select vary depending on whether you specify a time-domain or frequency-domain input signal.
If you want, for example, make a change of units of a power spectrum you can use the VI " Spectrum Unit Conversion". Hope that help
(5,647 Views)
