SignalExpress
Signal Express version unknown problem with Labview VI
Hi All,
I am trying to run Labview VI 2010 in Signal Express. It gives me "version unknown" problem. When I checked the versions for Labview it says 10.0f2 and the Signal Express can read LabView 2010 version. I don't understand this. Isn't 10.0f2 just a patch for 10.0 version ? I will appreciate it if someone can help me out with this.
Kanu
Message 1 of 11
(10,247 Views)
Accepted by Kanu
Hi Kanu,
I tried writing a simple VI and importing it to Signal Express and I had no issues. I am using LV2010f2 32 bit and Signal Express 2010. I have attached the VI that I used so that you can try it yourself. I followed the instructions in this [link removed; article no longer available] KB to create a source file distribution. If you follow this KB and still can't get it to work, can you please post the VI?
Message 2 of 11
(10,231 Views)
Hi Paul,
Thanks a lot. I was trying to directly run the VI without creating LLB and building it. My problem is solved 🙂 .
Kanu
Message 3 of 11
(10,220 Views)
Hi Paul,
I have one more question. Is there a way I can import signal express VI into labview VI ? Also, I need to do certain modification to the signal express VI.
Kanu
Message 4 of 11
(10,213 Views)
Hi Kanu,
To generate a LabVIEW VI from signal express code, go to Tools » Generate Code » LabVIEW Diagram. You will be prompted to save the VI and then it will be created for you. You can read this [link removed; article no longer available] KB for some caveats pertaining to VI generation.
Message 5 of 11
(10,198 Views)
I have a question here.Could you please help me solve it.It's about importing LabVIEW VIs into LabVIEW SignalExpress as Steps.
I have read Getting Started with LabVIEW SignalExpress ,and I can import Limiter-LV86.vi in the SignalExpress\
Examples\Tutorial into User Step.seproj. But when I build a new VI myself ,the INPUT and OUTPUT is gray.Then I build another file by copying Limiter-LV86.vi,and it shows the same. I dont know why.
Thank you very much for reading this.And I wonder if you could please send me some other examples(I mean some VIs which can be imported into  LabVIEW SignalExpress as Steps)
Message 6 of 11
(9,898 Views)
Hi!
This KnowledgeBase article should be fairly helpful for your application. It shows you how to configure your VI to work with SignalExpress.
Using a LabVIEW VI with LabVIEW SignalExpress [link removed; article no longer available]
One thing I noticed when I opened your My File VI is that you did not have your connector wired. This would cause those Input and Output areas to be grayed out.
Also, one thing at the end of that KnowledgeBase that should be noted: You cannot run a VI that was saved for a previous version of LabVIEW using the Run LabVIEW VI step in Signal Express. You must save the VI in the actual version of LabVIEW you specify in the Run LabVIEW VI step.
I hope this helps!
Kim W.
Applications Engineer
Message 7 of 11
(9,881 Views)
Your help is greatly appreciated, and I'm grateful for it.I have solved the problem.
Message 8 of 11
(9,862 Views)
I have another problem now. It's about importing LabVIEW VIs into LabVIEW SignalExpress as Steps too. I try to add a Filter in a LabVIEW VI,and the VI can be imported into SignalExpress as Steps. I know  we can  add a filter :add step-->Processing-->Analog signals-->Filter. However,I want to expand the functions of SignalExpress by importing LabVIEW VIs. I build a new VI myself and it shows:Error occurred in Run LabVIEW 8.6 VI step.
The VI is not executable. Please verify that the VI is not broken and saved as a Source Distribution (which "Includes vi.lib Files") and is within a Linked Library with the ".llb" extension.
I'm a beginner,and I don't know the reason.Could you please help me? I am using LV8.6  32 bit and Signal Express2009.Thank you very much for reading this.And I wonder if you could please send me some other examples(I mean some VIs which can be imported into  LabVIEW SignalExpress as Steps) .
Message 9 of 11
(9,847 Views)
This could be caused by one of two issues.
1: The VI that you are trying to open is broken and can not be run. Open the VI in LabVIEW and verify that it is operational in the LabVIEW development environment.
2: The VI isn't built into a source distribution that is compiled as a library that includes the vi.lib files.
To do this you need to:
  1. Add your VI to a LabVIEW project.
  2. Create a new source distribution in the project by right clicking Build Specifications and choosing New»Source Distribution.
  3. In the build specifications make sure to set your VI as the startup VI in the source files category.
  4. Under the Destinations category, change the type to LLB.
  5. Under the Additional Exclusions category, uncheck the Exclude Files from vi.lib.
  6. Build the Source Distribution.
  7. In SignalExpress, where you would normally select your VI, choose the .llb first, and then the VI from within the library.
Message 10 of 11
(9,829 Views)
