SignalExpress
SignalExpress 2012 does not recognize cDAQ-9188
How can I setup SignalExpress to communicate with the cDAQ-9188 module?  I found the system in MAX but I can see no device connected in the Channel View.
Message 1 of 11
(8,302 Views)
The cDAQ-9188 is a chassis.  What modules do you have in it?  It is the modules that will show up in SignalExpress.
Message 2 of 11
(8,299 Views)
Thanks for the reply, do I have to have LabView to run SignalExpress?
I have 2 NI 9205 and 3 NI 9221 modules inside the cDAQ9188 chassis.  All modules can be seen in MAX but not from SignalExpress 2012.
Message 3 of 11
(8,294 Views)
Hi Runner,
I'm not sure if it was caused by DAQmx driver. What's the version of your DAQmx driver? When I use MAX to simulate 9221 then it can be displayed in SignaleExpress in Add Channels to Task of DAQmx Acquire step.
Message 4 of 11
(8,290 Views)
 Here is the software version display from MAX.  I switched to SignalExpress 2010 becasue this is the one that come with the hardware.
Message 5 of 11
(8,284 Views)
Hi Runner,
I saw there is nothing in your channel view, could you please check the version of your NI-DAQmx driver from Control Panel>>Uninstall a program>>National Instruments Software?
Here is my channel view:
And here is the version of NI-DAQmx:
You can download the latest DAQmx driver here: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
Message 6 of 11
(8,280 Views)
The DAQmx version is 9.2.1.  it came with the hardware.
Message 7 of 11
(8,276 Views)
Hi Runner,
Could you please try to install NI-DAQmx 9.5 or above? I thinke NI-DAQmx 9.2.1 is only support SignalExpress from 2.x to 2010.
Message 8 of 11
(8,272 Views)
I installed DAQmx 9.5.1 and still not working.
When I run the self test, I got an error message - Error -201388 occured at self-test
Message 9 of 11
(8,253 Views)
Runner.
Do you have any other devices connected?  Are you trying to access the chassis from multiple programs?
J Newk
Systems Engineer
Message 10 of 11
(8,239 Views)
