08-24-2012 05:07 PM
How can I setup SignalExpress to communicate with the cDAQ-9188 module? I found the system in MAX but I can see no device connected in the Channel View.
08-27-2012 07:50 AM
The cDAQ-9188 is a chassis. What modules do you have in it? It is the modules that will show up in SignalExpress.
08-27-2012 08:50 AM
Thanks for the reply, do I have to have LabView to run SignalExpress?
I have 2 NI 9205 and 3 NI 9221 modules inside the cDAQ9188 chassis. All modules can be seen in MAX but not from SignalExpress 2012.
08-27-2012 10:16 AM
Hi Runner,
I'm not sure if it was caused by DAQmx driver. What's the version of your DAQmx driver? When I use MAX to simulate 9221 then it can be displayed in SignaleExpress in Add Channels to Task of DAQmx Acquire step.
08-27-2012 10:39 AM
Here is the software version display from MAX. I switched to SignalExpress 2010 becasue this is the one that come with the hardware.
08-27-2012
10:54 AM
- last edited on
04-11-2025
10:50 AM
by
Content Cleaner
Hi Runner,
I saw there is nothing in your channel view, could you please check the version of your NI-DAQmx driver from Control Panel>>Uninstall a program>>National Instruments Software?
Here is my channel view:
And here is the version of NI-DAQmx:
You can download the latest DAQmx driver here: https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
08-27-2012 11:47 AM
The DAQmx version is 9.2.1. it came with the hardware.
08-27-2012 02:20 PM
Hi Runner,
Could you please try to install NI-DAQmx 9.5 or above? I thinke NI-DAQmx 9.2.1 is only support SignalExpress from 2.x to 2010.
08-29-2012 09:16 AM
I installed DAQmx 9.5.1 and still not working.
When I run the self test, I got an error message - Error -201388 occured at self-test
08-30-2012 08:38 PM
Runner.
Do you have any other devices connected? Are you trying to access the chassis from multiple programs?
