SignalExpress
Single trigger output pulse each iteration
I want to output a trigger pulse, record two analog inputs, and save the data to a text file.  When I do this for one iteration it works fine, but multiple iterations only acquire and save, the output pulse is only generated on the first iteration.  I am using a counter pulse output to generate the signal. How can I fix this issue?
(5,758 Views)
Hi there,
What kind of board are you using? Are you saving data to the file on every iteration? Depending on your application, it might be advisable to save all data to a file after you are done with your application. Can you post your code so that we can look at it?
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(5,735 Views)
