SignalExpress
Viewing TDMS file created in LabVIEW in Signal Express
I've generated a set of data in LabVIEW and logged it to a TDMS file.  I can read this file back within LabVIEW and see the original data.
I then try to read this file in Signal Express.  The import of the data directory works, but there is no "+" around the log file to expand the data to display.  This is done even with data generated from the TDMS example files delivered with LabVIEW.  I have attached the TDMS and TDMS.index files for anyone who wants to try the import into Signal Express.
Message 1 of 16
(11,321 Views)
Hi Eatherton,
Please find the attached files. The word document includes the instructions that you need to follow, and I have also attached the .zip file and the VI.
Eli S.
Message 2 of 16
(11,307 Views)
Thanks for that reply.  I'll try it out this afternoon.  Do you know if this is a known bug within Signal Express and will be rolled into a future release?  Just for my FYI...
Message 3 of 16
(11,301 Views)
Hi Eli,
I am working with Eric and tried out the installer but it does not recognize the utility in the zip file.  Any suggestions?
CEK
Message 4 of 16
(11,293 Views)
I have just tried this and it worked. Make sure that you unzip the whole thing into a folder before running the installer.
Eli S.
Message 5 of 16
(11,262 Views)
Eli_S,
Just tried the installer, and it works great!!
Thanks again!
Message 6 of 16
(11,240 Views)
Hi all,
I have a question, not being a signal express user, is it possible to save data in a TDMS format (using SE)?
If so, then the process is reversable with regard to Signal express to Labview.
Regards
Xseadog
Message 7 of 16
(11,187 Views)
You can save data in LabVIEW and Signal Express in TDMS format.  It is very easy in LabVIEW, all of the VI's are off of the File I/O pallet.  You can read TDMS files in LabVIEW that were generated in Signal Express.  The problem I was having is that I could not import data saved in LabVIEW TDMS into Signal Express.  This fix works with that problem now.
Message 8 of 16
(11,170 Views)
Hi forum,
should the import also work with the evaluation of signal express? I import a tdms file generated by an example of LabWindows/CVI (tdmsWriteBenchmark). The example tdms-Reader works with the generated benchmark data. In Signal express i could import the benchmark tdms file too, but I can only see the log file, but there is no data (e.g. group, or channel(s)). Also after installing the conversion utility (http://digital.ni.com/public.nsf/allkb/3CEAF51888A117EC862573980061D585) the channels are not visible.
Thomas Lüttecken
Message 9 of 16
(8,367 Views)
Hi Thomas,
Has your trial of Signal Express expired or are you still within the 30-day period? Once the 30 days has expired, the functionality is reduced according to this chart (http://www.ni.com/labview/signalexpress/purchasing-options.htm).
Message 10 of 16
(8,349 Views)
