SignalExpress
What's the difference between RSE and differential terminal configuration?
I'm seeing some "digital" (noise that is at a constant value offset from the stable signal value) noise when viewing 2 pressure signals through a NI USB 6008. I currently have the terminals configured to RSE, is that correct? The Transducers are 1-5VDC output analog.
(33,792 Views)
This document will help you to choose the correct configuration. (RSE --> used for floating sources like batteries)
(33,784 Views)
Which doucment? I am also wondering about RSE and what it does
(23,205 Views)
I hope this document helps you to clarify your doubts about the RSE and differential connection.
Field Wiring and Noise Considerations for Analog Signals.
(23,178 Views)
I use differential mode whenever possible.
Makes for a much cleaner signal in many cases
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(23,164 Views)
