SignalExpress
Determining the time in my data file I've exported from signal express
I am trying to understand the time of my data file I've exported from signal express. If I'm using continuous samples with the rate at 330m and the samples to read set for 1, what is the time difference in data points? I initially thought it would give me data samples roughly every 3 seconds, but there are so many data points I think it's capturing much faster.
(5,261 Views)
What hardware/modules are you using.
Some modules have a minimum sample rate.
See this post
http://forums.ni.com/t5/SignalExpress/Slow-Log-Rate-Needed-using-cDAQ-9174/td-p/3163388
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,234 Views)
I am measuring current using the NI 9203 in the NI cDAQ-9174 bus.
(5,231 Views)
If you want 3s/s try setting your Hz to 3 and sampes to read to 3.
Assuming the device will sample that low.
PCI 6281 DAQ card
Win7 Enterprise
(5,220 Views)
