SignalExpress
When entering the rate in signal express how do I indicate multiples?
When I set the rate in signal express I use 330m. Is that indicating 330 millihertz?Would I use Mu to indicate microhertz?
probably a dumb question, but Im having to teach myself this program.
(5,059 Views)
"330u"
or type the decimal equivalent which would be .000330 and SigEx will smarten it up for you once you click out of the text box
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,023 Views)
