SignalExpress
Will I have problems sharing the same .seproj file between multiple SCXI's
We have multiple "mobile" work carts for DAQ needs; each with it's own SCXI Chassis and PC running Signal Express.
If I were to store the .seproj files on a network can I use the file with any of the SCXI carts or are there calibration and sensitivity values specific to the hardware that are written to the .seproj file?
An example of why I ask is this: I may configure a SigEx project for a test with one of the SCXI carts, run the test and send the data to the engineers for review. While I'm waiting for further direction on that test another test may be in progress, so I'll move the cart over to it, but this test is several days long and ties up the cart for the duration of the week. Meanwhile, Mr. Engineer comes back and wants me to take a few more samples of that first test but the SCXI cart I used to take the original data is tied up; but there's another SCXI cart available and not being used...   Here's where the sharing of .seproj files comes in. If I store the .seproj file on a network I could access the test file with any cart assuming all things (hardware related) are equal.
I'd roll another SCXI cart over, plug all the channels into the modules, call up the .seproj file from the network and be off and running...
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(5,929 Views)
Hi OKors,
I can't think of any problems from sharing SignalExpress projects on the network.  Make sure that all your hardware is selected correctly when you open the seproj file and this should be just fine.
Jim Schwartz
(5,919 Views)
