SignalExpress
can you have set points for analog inputs
if you install an analog input can you get set points that trigger either an alarm or a motor to turn on or off
(6,188 Views)
Accepted by topic author pstew
In SignalExpress you can use alarms for triggering logging on and off:
Alarms Page - LabVIEW SignalExpress Help
As for turning motors on and off, SignalExpress is not meant for control applications.  For controls, you should use LabVIEW either entirely or use a LabVIEW VI from SignalExpress.  To do the latter, you could use a LabVIEW VI step in SignalExpress that will execute a LabVIEW VI that does the control processing and outputting that you want.  That way you could work in the SignalExpress environment for all the data acquisition, and you would only have to use LabVIEW to program the control VI (or VIs).
Mark E.
(6,173 Views)
