SignalExpress
how to send signal out from PCI 6010
I'm using signal express 2010 liecensed version. Now I want to create an AC signal and send it via NI PCI 6010 to servo motor. I tried many time, but it does not work. I click the  example, signal express is automatically closed. Pls help.
(5,615 Views)
I am not sure if this is the problem but I have a NI6010 and the analog output is rated as "Static". From the work that I have done with mine this means that you can't change the output very quickly. I never really tried to see how fast it can change but it is slow. I don't know how that plays into the signal you are trying to sent your servo.
(5,610 Views)
