SignalExpress
<ERR>Driver Status: (Hex 0xBFFA2003) Max Time exceeded before operation completed. (TEK DPO2014)
Hi NI.
I'm trying to aquire signals from an Tektronix DPO2014 oscilloscope using Labview SignalExpress.
I have downloaded and installed the appropriate driver (at least I think :manhappy:)) : tkdpo2k using NI download station.
I run an ethernet connection and I do see the device in MAX, however im not quite sure if I have configured the IVI driver sessions correctly.
Anyway, when I open Signal Express, and select "IVI scope aquire" I can select my device under "resource descriptor" and the appropriate driver under "Instrument driver". I then turn on my Oscilloscope, tune in the machines tachogenerator, which is the signal the oscilloscope is to measure, and then select "autosetup" The sinosoidal waweform shows up on the oscilloscope and in SignalExpress, it is only done once. I then try and run the program and the error message accurs:
Timeout.
Is the problem regarding problems with triggertime or write/read problems with the TCP/IP connection?
What can I do to fix this problem?
Best Regards
Danny Joergensen
University of Aalborg Denmark
Message 1 of 1
(6,410 Views)
