SignalExpress
offset doesn't work
Hello guys,
Have a problem with signal express. I am just building a simple test.
As Figure 1 shows, target singal is normal sine wave with 1V offest.
        Figure 1
Figure 2 shows that the offset effect quickly dishminished on the generated signal (detected).
        Figure 2
I am very confused on this phenomenon. Anyone can help give an explanation?
If I want to a normal sine wave with steady offset, what should I do?
Thank you
Kevin
(5,994 Views)
Accepted by KevinLilian
Hey Kevin!
The reason that's occuring is because you are using AC coupling on your input, so the DC component is being filtered out. The PXI-4498 is an AC coupling only device so unfortunately you won't be able to read that 1V offset on the input.
http://digital.ni.com/public.nsf/allkb/0F81C33977056A7D862566F1005CAA71
The following user guide is where it states the 4498 can only perform AC coupling:
http://www.ni.com/pdf/manuals/372125f.pdf
Hope this helps clear things up!
Rob B
FlexRIO Product Manager
(5,968 Views)
Thanks Rob,
It helps.
Kevin.
(5,953 Views)
