SignalExpress
set high input impedance on Tektroniks DMM4040
Hi Nick
here's the screenshot.
Message 11 of 15
(3,421 Views)
hcastor,
Are you using the Tektronix Edition of SignalExpress?
Nick
Applications Engineer
Message 12 of 15
(3,407 Views)
affirmative
Message 13 of 15
(3,404 Views)
Hi hcastor,
I was under the impression that you were using the normal edition of SignalExpress, not the Tektronix. I apologize for that.
It does not appear that there is any way to change the input impedence of the DMM through SignalExpress Tektronix Edition version that you are using.  If you are not able to simply click the DMM and see the setting, there is no hidden way to change this.
As far as the timing, that does not look like you can do anything extensive either. This is usually done in LabVIEW.  Similar to how you checked for the impedence, if you can't click on the DMM and see the setting, there is no hidden way to get there. You can play around with the DMM itself and see if you can change the timing on that, but it doesn't appear that you can do this in SignalExpress Tektronix Edition.
Nick
Message 14 of 15
(3,394 Views)
Accepted by hcastor
Hi Nick,
many thanks for the answer, I'm really grateful to know this now. I wish there had been a way to do those things, but it is also helpful to know they can't be done.
They would be helpful features to implement in a future release of SE. The Tektroniks multimeters are really fine instruments. It's a pity that you can only use their most basic functions under SE.
Message 15 of 15
(3,392 Views)
