SignalExpress
the selected log is not prepared for viewing error
this is literally my first day using signal express and up to now everything went fine recording voltage from accelerometer and an impact hammer. Without me changing any parameters as far as I remember I now get the errror 'the selected log is not prepared for viewing. Once recording has completed you must right-click on the log and select Make log viewable before viewing it'
Apart from the fact that there is no such option on the log (only the option of Show Value by right clicking)
I went to Tools--> Options--->Logging and made sure that the prepare log data for viewing is on the 'during logging' option.
I then changed that to 'after logging complete' to see if the error stops but nothing yet.
Any help would be appreciated
(5,271 Views)
Hey Sobeit
Could you post a screenshot of the error that you are getting.
(5,186 Views)
turns out the problem was linked with not having enough space on the server were I saved the logs...when I deleted some previous work to make up space everything worked just fine. Problem solved, thank you for your interest.
(5,183 Views)
