SignalExpress
using timing and transition function
Hello
I want to use the timing and transition function to find out the frequency, period and pulse duration of the input AC signal but it shows the error that the waveform didnt cross the mid reference level enough times this measurement. Check the signal length, reference level and ref level units. Can any one know how to set these parameters.
Thanks in advance
Ali
Message 1 of 1
(5,246 Views)
