SignalExpress
unable to read shared variable in signal express
Dear all,
I am trying to read a shared variable with data type 'Array of Double Waveform' and the signal express gives a network variable error stating
"The data type of specified shared variable xxxxxx is not supported".
could any one explain why is this not supported or suggest a work around.
Munir.
(6,172 Views)
Hi Munir,
the datatype you want to use is not supported in Signal Express. So if you choose this datatype you always get this error massage. As a work around I can recomment you to take the Double Waveform datatype this is supported, create a shared variable for each array element (waveform) and read this variable in Signal Express. This should help you out.
If you got any questions feel free to ask me.
Regards
TomBaum
(6,160 Views)
