SignalExpress
using RFSG with signalexpress
Hi
can i generate an RF signal in range from 200-400Mhz with PXI-5670 RFSG using signalexpress 3.0 ????
if the answer is "yes", then HOW TO DO THIS???.
i m able to generate the signal with PXI-5421 (AWG) but how th upconvert this signal in signalexpress with PXI-5610 (upconverter) ??? as i havent seen a step for upconvertion of the signal generated by PXI-5421.:smileysad:
I need all of this because i want to generate a hopping signal using signalexpress with PXI-5670 (RFSG) above 200Mhz.
help in any form i.e. text files(manuals) or VI's will be really useful for me.
REGARDZ
ADNAN FAZIL
RESEARCH ASSISTANT
AIR UNIVERSITY
PAKISTAN.
(6,384 Views)
This is a duplicate post, please go here for the active thread.
Dan King
(6,356 Views)
