05-22-2012 06:00 PM
I am working on one project. In which I have CCD image sensor with EIA B/W video camera and its output is connected to Analog Front End(AFE). The output of AFE is 12 Bit Digital data at the rate of 9 MHz. I am thinking to use USB 6509 for data acquatision from AFE. Actually I want to produce one video file(e.g. 30 second video) from the AFE that is the reason I am using USB 6509 to get the digital data in my computer.
I know USB 6509 is compatible with LABView SignalExpress software.
Now, My question is, as I have data to my computer using USB 6509. How can I generate video file (preferrable lossless compression) from the digital data using the SignalExpress or Do I need any other software?
FYI: I am new to LABView.
05-23-2012 06:39 PM
Hi erhk,
SignalExpress will not be able to create a video/image from the data; though, it will allow you to acquire it. If you can get the data into a 2D array of pixel values, you can use LabVIEW with the Vision Development Module to create a video with it. There also may be other programs out there that can convert the 2D array to a video/picture file.
05-24-2012 12:51 PM
And you certainly will not be able to capture 9MHz data with the 6509. As you can see from the specs, it is software timed.
05-24-2012 01:32 PM
		05-24-2012
		02:28 PM
 - last edited on
		02-18-2025
		01:07 PM
 by
			Content Cleaner
