SignalExpress
why signal express 2.5.1 and 3.0 is crashing with labview 8.6
Hello.
i am trying to install the evaluation version of signal express 2.5.1 and 3.0  on my labview 8.6, it installs correctly but when i go to see the pallette tools, i see nothing.
i try to open it directly, it is crashing, and labview 8.6 is working correctly.
thank you
(6,142 Views)
boulos,
LabVIEW 8.6 will actually install SE without you having to do anything extra. The only thing that I can think would be causing this crash is that LabVIEW installed SE and then you tried to install an older version, which messed with the dependencies.
You can check what version of SE you currently have in MAX or License Manager. I might check your NI License Manager (Start>>All Programs>>National Insturments>>NI License Manager) to see if you have any issues seeing it there.
Chris Van Horn
(6,133 Views)
