SignalExpress
Why cant a shared variable be viewed as a chart in SignalExpress
In SignalExpress I add a step to read a shared variable. I can view it in Graph mode but not Chart mode. Can somebody explain why that is? Am I doing something wrong?
kind regards
Frank Greenslade
Christchurch
New Zealand
(6,470 Views)
Frank,
What is the data type of your shared variable?
It is possible to view a numeric as a chart or graph, but when dealing with waveforms, the graph option is the only one available (either XY or Waveform Graphs). I attached some screenshots of what I believe you are seeing to confirm that this is expected behavior.
Is there a reason you want to use Chart Mode?
Peter Flores
(6,457 Views)
Accepted by topic author FRG
I found the problem was the data type. Signalexpress wont view array of double as chart.
(6,450 Views)
