Sound and Vibration
How to save audio file in this VI
I was trying to record and save audio signal in this VI. But unfortunately I couldn't able to save the audio file. while i was trying to save the audio file as .wav type my music player couldn't play the audio. could anyone help me to save the  audio file.
(7,060 Views)
In LabVIEW if you go to the example finder under the help menu.
You can search for a VI called "Sound Input to File.VI"
My advice would be to look at and understand that VI, It will do what you want, and the API used in that example will prove more portable depending on what you want to do with the code.
If you do have any issue or further questions please mention which version of LabVIEW you are using as it helps us provide the best advice.
Have a great day,
(6,311 Views)
