Sound and Vibration
vsr balancing machine
hello
im new here and beginner in labview
im interested to make a machine for balance turbocharger
i build mechanical parts , but i need your help for make a software
im using a vibration sensor and accelerometer
i home for your help
thank you
(7,904 Views)
Mihai,
I would advice that you download Sound and Vibration Measurement Suite
It has an example project of how to use LabVIEW to do a balancing solution.
Let me know if I can provide more input.
(6,879 Views)
Mihai,
If you are new to LabVIEW and you are putting together this type of system, I would recommend that you look at working with a systems integrator.  The company I work for, Signal.X Technologies, specializes in noise and vibration testing for rotating machinery.  You can check out our integrator profile at www.ni.com/signalx.  We have done a number of balancing solutions, and have a lot of experience in this area.
Thank you,
Robert Hoffman
hoffman@signalxtech.com
(6,879 Views)
